Recommended spark plugs
Old Jun 16, 2004
  #31
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
if it aint broke, dont fix it.
your running the risk of damaging your engine by putting new plugs in when they arent needed.
Old Jun 16, 2004
  #32
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
The Denso Iridium IK20's are a total waste of money. They don't help performance any more than any new, properly designed plug would. No noticeable difference of any type (MPG, performance, smoothness, etc) versus the stock NGK's.
Old Jun 16, 2004
  #33
You will notice a difference if the stock plugs are getting bad. I still say stick with ngk for plugs. I have iridium and it's nice and smooth.
Old Jun 16, 2004
  #34
Pharoh's Avatar
Bobaganoosh!
same here. Changed 'em out a couple of weeks ago (78,000 km's). Lovin the NGK Iridiums
Old Jun 19, 2004
  #35
VTEC01EX's Avatar
I just ordered up some NGK IX's... I'll report back after I get them and put em in.
Old Jun 21, 2004
  #36
ponyman's Avatar
ponyman is on a distinguished road
Umm....Yeah...only if you a) put them in wrong b)put in the wrong spark plugs, or c) do not properly gap them...but thanks for playin
Old Jun 21, 2004
  #37
ctx66's Avatar
thanks for playin? what the hell is that supposed to mean? the chances of him properly torquing the plugs down with anti-seize is slim to none. wont happen, engine will suffer as a result. have fun with your $50 spark plugs in your basically stock civic ponyman. moron.
Old Jun 21, 2004
  #38
ponyman's Avatar
^^^Alright, whatever...I'm just saying that if people are going to fu(k up an engine that it isn't going to be because of spark plugs...but the name calling, that is cool too....
Old Jun 21, 2004
  #39
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Let me get this right you think that some one can actually ruin their engine because they change their spark plugs too soon? LOL
What’s with the name-calling? Should you intimidate us?
Old Jun 21, 2004
  #40
Well okay. All these fancy plugs won't help at all on a stock car. Only reason I got mine were to replace the stupid stock plugs that were ruined. Oh and if you don't torque the plugs to the right specs, you WILL blow the engine eventually from overheating.
Old Jun 21, 2004
  #41
zen_master's Avatar
la la la....
NGK iridium IX, torqued at 13 ft/lbs....18N/m...
Old Jun 21, 2004
  #42
EManEX's Avatar
Maybe you could blow your engine, but wouldn't you be able to tell that there is a problem with your ignition system. Now if the problem starts after installing your plugs then you will know it has something to do with the plugs; only a stupid person wouldn’t try to fix it.
I think that if you don’t torque the plugs to proper setting then you run a higher risk of stripping it (whish you will know as soon as you striped the head), or too lose and having the sparkplug shoot out of the head.
Old Jun 22, 2004
  #43
ctx66's Avatar
by changing plugs too soon? no. by improperly changing them? yes. spark plugs do a lot more than produce a spark.
whyd i use the name calling? because someone else had to initiate the immature behavior by thinking he knew everything and thought they had shut me up.. or somethin
Old Jun 22, 2004
  #44
pnoyster2k1cvic's Avatar
Balut Eating Champ
Originally Posted by R3DL1N3
denso IK20's
I got em too! hella expensive, but worth it, smooth idle, quick start... I've been spraying for almost a bottle with no problems no signs of detonation either...
Old Aug 14, 2004
  #45
UltimateWarrior's Avatar
Pimp My Ride!! Please!
UltimateWarrior is an unknown quantity at this point
Originally Posted by zen_master
la la la....
Um, this may sound silly but how do you set a spark plug for torque? Are you just talking about setting the gap? If so, how does that relate to torque? Sorry, I don't know much about engines. I've always just purchased plugs and set the gaps to whatever the owner's manual said. But that's just me...
Fill me in here dude!
Old Aug 14, 2004
  #46
Torque is how tight you turn the plug in the cylinder. There are special torque wrenches that measure this. Mine has a needle that goes up as you turn it. When it reaches 13 ft/lbs, you stop tightening.
Old Aug 14, 2004
  #47
Oh yea, DUH! I remember that now. Sheet, I forgot all about that! Ok, now I have to either borrow or purchase a dang torque wrench.
Thanks for the helpful hint to refresh my small brain...
Old Nov 14, 2004
  #48
wez20011's Avatar
wez20011 is an unknown quantity at this point
anyone ever tried splitfires? is it any good? or iridiums are better? i tried denso iridium on my old car it kinda was good but was wondering if splitfires would be better.
Old Nov 14, 2004
  #49
Pharoh's Avatar
Bobaganoosh!
those are junk. I've been using NGK for over 12 years on everything from a 1974 Camaro to my honda civic. Denso aren't bad but I don't think they're that much more special than NGK considering the retarded price tag on them.
Old Nov 17, 2004
  #50
wez20011's Avatar
I used denso iridium ik16 for my 1.6 sentra before. it worked great since i installed tehm before, they never fouled up again unlike my old copper type spark plugs.
My bro uses splitfire tripple platinum on his Si. and it helped somewhat on his low end torque. since his car is fitted with cams and all that...
was wondering if I should go with denso's iridium or Splitfire tripple plats? they are almost priced the same here in our place.
I sold my sentra and got an 04 civic vtec, (1.6 3 stage vtec) since we don't have the 1.7 d17 available here. but it's almost the same thing we have the same head and tranny. just wondering if you guys have the same vtec also
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
Micks2K1
Dec 10, 2001 07:11 PM
