Throttle Position Sensor
Old Feb 2, 2004
ReD2k1's Avatar
ReD2k1 is an unknown quantity at this point
Anyone know where i can buy a TPS from wether itd be new or used i dont mind thanx
Old Feb 3, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
you cannot buy just a TPS for our cars. you have to buy a whole new TB.
Old Feb 3, 2004
tavdawg's Avatar
tavdawg is an unknown quantity at this point
Why wouldnt they sell it seperate? Mine has a faulty one in it right now, but the dealership says its good. So im gonna have a fun time trying to get them to replace it under warranty.
Old Feb 3, 2004
marc-111's Avatar
marc-111 is an unknown quantity at this point
my dealer don't want me to claim it as a warranty because when i installed my col-air i kinda hit it and has an crack on the side, now im looking for a nice second hand TB
Old Feb 3, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
WWW.CAR-PARTS.COM
Old Feb 3, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
naw if you want a TB go for the group buy DH racing CNC port and polish TB it will cost less plus get you some gains, its better to buy a Aftrmaket then a oem.
Old Feb 3, 2004
marc-111's Avatar
nice idea but i think that GB needs a core, and my core is not working right
Old Feb 3, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
PUT SOME thought into ur posts people.
they p & p YOUR throttle body... they dont include sensors. moron.
eh that was kinda mean.. lol dont mind me im just a ****
Old Feb 3, 2004
Kloverz's Avatar
Man it was just a idea I understand they dont include the sensor but thats not what im trying to preach YOU DUMB ****. Keep your sh1ty comments to urself and stay on the topic and you should think before you open your LIPS.
Old Feb 3, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I don't see why they wouldn't sell it separately. Go to Majestic Honda
and get their number and call them up and order. It's cheaper than the usual Honda dealerships. Or like Vin said, try www.car-parts.com.
He was staying on topic.
Old Feb 3, 2004
ReD2k1's Avatar
aright i went to the majestic honda website and they have the throttle body for a lot cheaper than the dealer over here was gonna charge me which was close to 230, but id rather buy a used TPS since it would be a lot cheaper, im gonna keep looking thanx a lot
Old Feb 3, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
www.car-parts.com
Old Feb 3, 2004
YS's Avatar
YS
YS is an unknown quantity at this point
ok ....... what is Throttle Position Sensor??
What# -->>
Thank you kindly
Old Feb 3, 2004
marc-111's Avatar
right under part number 18
Old Feb 3, 2004
streetglower's Avatar
thats true, when my check engine light came on a while ago I went to auto zone and they said it was the throttle position sensor, when I took it to the dealer, they had to replace the whole throttle body.
Old Feb 3, 2004
YS's Avatar
YS
what does it do?? what happen when it goes bad??
Old Feb 3, 2004
sometimes when they go bad,if you have an auto tranny, you wont be able to get out of park unless you open that little box that sits next to the handle and place your key in there and turn it, pain in the ***. Also your tranny will mess up.
Old Feb 4, 2004
marc-111's Avatar
for my experience when i mess up (advanced turnd it ) my TPS my RPM went up and my gas milage is so high!!!! my RPM in neutral is 1,100, thats why i dont use my car everyday until a buy a new TB
Old Feb 4, 2004
flotsamm's Avatar
The TPS is used to control rpms. Its controlled the the ECU. The ECU tells the TPS where to set the rpms at. For instance, when the CTS(coolant temp sensor) reads that the coolant is cold, it tells the ECU that the engine needs to warm up. So the ECU tells the TPS to run at a higher rpm until the coolant temp warms up, then start reducing the rpms until normal operating temp is reached.
Sometimes they get gummed up and can be cleaned using a carb cleaner thats safe for rubber seals...
Old Feb 9, 2004
ReD2k1's Avatar
yea my clutch shutter also when i get out of first gear its really annoying
Old Feb 9, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
you could try a auto salvage place... I got a rear bumper cheep after someone hit my car in a parking lot... they had almost every part except form the drivers fender back to the gas door.
Old Feb 11, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Well that really sux... Can we put a bigger TB on our car with the stock POS IM???
Old Jul 17, 2004
Is it possible to adjust the TPS manually to change the idle rpms?
Flipg123
May 8, 2015 01:15 PM
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
tkcne
Apr 18, 2015 02:33 AM
RX7T2
Mar 4, 2002 06:13 AM
