air intake/cold air intake
Old Jan 18, 2004
dobe's Avatar
dobe is an unknown quantity at this point
What's the difference between a Cold Air intake and an air intake? If there is any
Old Jan 18, 2004
ragencajun's Avatar
ragencajun is an unknown quantity at this point
yes the temp of the air the colder the air the more dense and better for combustion.
the cold air intake usually is longer and draws air from out side the main part of the engine bay. as the regular aftermarket intake draws air from beside or above the engine but is easier than the stock system to draw air porvideing more air on demand but at a little warmer temp.
Old Jan 18, 2004
streetglower's Avatar
to better explain this, a regular intake usually draws in the hot air, usually the air from under the hood, as where a cold air intake, the filter usually sits behind the bumper and draws in the cold air through the fron or sides of the bumper.
Old Jan 18, 2004
Don't get one. I speak from personal experience when I say it doesn't do anything on our cars. I even lost some low-end power. Not worth it.
Old Jan 18, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
no matter if its a cold air, or short ram the only difference the two have over the stock intake system is it sounds alot better and dresses up the engine bay alittle i guess, no power gains, maybe like 2
Old Jan 19, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Get the PnP head
Old Jan 19, 2004
IronFist's Avatar
Cold air is in theory better, but a lot of times since a cold air intake is longer than a short ram intake, the extra length of pipe slows the air down. So with a cold air intake you get less, colder air, and with a short ram intake you might get more air, but it's warmer.
If you want an intake, get the K&N FIPK II. It's a short ram intake but it has a heat shield so you don't get warm engine air. Plus, the tube is plastic so it doesn't get hot. Most intakes have metal tubes that get very hot under the engine. Yes, intakes don't do that much for us, but if you are going to get one K&N FIPK II is the best (and there's no low end loss of power like with the other intakes).
Old Jan 19, 2004
Philip's Avatar
Philip is an unknown quantity at this point
how about RAM air? that **** really works good..
Old Jan 19, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Philip Search This has been talked about over 1,000times
Old Jan 19, 2004
Hey ironfist, did you just save that reply somewhere? I've seen you post it in every intake thread, lol.
Old Jan 19, 2004
marc-111's Avatar
marc-111 is an unknown quantity at this point
cold air intake draws air outside while the air intake draws air from the engine heat "fans"
here's my custom made coldair intake!!!
Old Jan 20, 2004
IronFist's Avatar
lol, no, I should tho. It's like when someone wins one of my eBay auctions... I have my "you're the winning bidder" email that I send them memorized.
hoofboy
Jul 17, 2015 04:27 PM
NoobyKid
Jul 13, 2015 07:53 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
