Super Cheap Engines???
some kid showed me this webpage. and they have shady *** prices on their engines. i say theyre shady cus these engines come wiht mounts transmission ECU harnesses and all that for really cheap.
$5800 for a K20 Motor
- 6-speed LSD Tranny 4.7 Final Drive (Y2M3)
- ECU (PRC)
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
All that for only $5800?? or how about...
F20C (S2000) Motor, Tranny, ECU
Price: $ 4000.00 Plus shipping and handling.
Availability: In stock and ready to go.
- Motor
- Tranny
- ECU (PCX)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
whats up with this??? are these the reasonable prices?? or does it seem like a scam??
- ECU (PRC)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Motor
- Tranny
- ECU (PCX)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
I've seen a 6th gen hatch have a f20 in the car. Someone posted it here a while back. Search and you might find it. $5800 is about right for a k20a from japan. Of course the engine mounts that come with it are the stock mounts from that car. If you want to put it in a 7th gen coupe or sedan, that you have to go to www.hasport.com for mounts. But if you have the 02-up si or a rsx, you can bolt that sucker right in there. Whats the website?
Originally posted by CivicRookie
Eh, for a Type R K20, that's about the right price. And NO, the F20C won't fit in our Civics. Try an older hatchback...
5800 for a k20a wiht trans and all that i thought would be costing like 10k all together....my fault....... the website is www.hmotorsonline.com
mistermenphis22
Apr 3, 2016 08:06 AM
usajags84
15
Aug 19, 2015 03:12 AM
