The effect of underdrive pulleys on engine life
Old Oct 26, 2003
IronFist's Avatar
Post The effect of underdrive pulleys on engine life
When the topic of underdrive pulleys gets brought up, someone is usually quick to point out that they will make the engine wear prematurely.
Here is something I found about this. This guy installs and gives a review of underdrive pulleys. Read at the bottom where it says "Update- READ!!!"
Just thought it might help someone out. Pulleys haven't been brought up here in a while.
Old Oct 26, 2003
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
I only have the accesorie pulleys so they shouldnt have the same efect right
Old Oct 26, 2003
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
ive also heard that these pullets can cause you to blow a rod because of the pulley it could actually throw off the charge in your car this install is not for rookies just wanting basic mods
Old Oct 27, 2003
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
It will not have the same effect but the accessory pulleys does nothing for your car. Thanks for the info update IronFist
Old Oct 27, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
really good to know.....
Old Oct 27, 2003
neocivic01's Avatar
the Rage
neocivic01 is an unknown quantity at this point
good bit of info
Old Oct 27, 2003
PunkingCivic's Avatar
I need TP for my bunghole
wow
Old Oct 27, 2003
cdmx's Avatar
owell...
Old Oct 27, 2003
cdmx's Avatar
If i do, ill put my cracked stock pulley back on and blame it.
Old Oct 27, 2003
So you dont think the Aem accesorie pulleys do anything for our cars i felt a diff not a huge one but a little difference
Old Oct 27, 2003
Da1lyDr1ver's Avatar
thanks for the heads up 'Ironfist' good to know
Old Oct 27, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
why is your pulley cracked ?
Lt. Dan
May 13, 2015 12:42 PM
normaspirated
Jan 2, 2002 03:19 PM
HX
Dec 22, 2001 02:36 PM
TAZZ
Dec 5, 2001 09:35 PM
se7en
Nov 12, 2001 10:13 AM
