Aftermarket clutch?
Old Sep 14, 2003
Silverphantom's Avatar
Silverphantom is an unknown quantity at this point
Aftermarket clutch?
Wondering if anyone has installed a new clutch set and if it's worth it?
Old Sep 14, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yes its def one of the best mods ive done to my car.. i have the act extreme clutch kit.
Old Sep 14, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
where did you get it?
Old Sep 14, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
i have ACT 6puck with the 11.7lb flywheel..... any lighter is SILLY for a car that only revs to like 6800rpm....
Old Sep 15, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
exedy street sport. Awsome, just awsome IMO. Next best mod next to full suspension and Nitrous. Grips like a **** and is twice as short as stock. Plus, it is a bit stiffer. Made by same company that makes stock cutches. You can sell the car and no one will know the difference, only if they go up in the rev range and slam into geers
Old Sep 15, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yo ur nuts to get that clutch... 6 and 4 puck clutchs wear out 3 times as fast as the normal disc ones... thats why their meant for track use only...
Old Sep 15, 2003
bublik's Avatar
Truehonda.com
really, never knew that.
Old Sep 15, 2003
CarbonFly's Avatar
OsOBooSTeD, how hard was the install? Got any tips?
Old Sep 15, 2003
skipbarber's Avatar
you have to drop the transmission..its not easy to do. id suggest having it done professionally..unless you have a lift
Old Sep 15, 2003
Dr5D's Avatar
an how much is a cluch?
I know haveing the tranny droped would be $$$
Old Sep 15, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Did you get a new flywheel with that clutch?
Old Sep 15, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
honestly.. i had no experience in doing it and well im pretty good with my hands, ive installed my suspension and stuff like that.. well basically its pretty straight forward....remove the shift linkages, disconnect the clutch, u also need to remove the axles which requires undoing the two bolts that hold the front struts after you disconnect the the struts and the rotor falls, the axles can actually just be pulled out with alittle force.. its pretty easy to do . then unbolt the tranny, unbolt the motor mount on the side of the engine bay, remove it completely the engine will not move. then unbolt the one bolt that the tranny is connected to in the front of the bay....then u gotta wiggle the tranny off cause it slides on engine. make sure to have tranny fluid cause some is sure to fall out...
uhm... also ull need 12 point sockets to remove the clutch and flywheel... youll need to get the flywheel resurfaced also to prevent 'chatter' with the new clutch ... i took it to a machine shop (38bucks) and an hour of their time and that was done. when you reinstall the flywheel to the engine you need to use medium grade locktight on all 6 of the bolts. same thing aply's when reinstalling the pressure plate and clutch, locktight on all the bolts. make sure the kit comes with an alignment tool cause thats KEY. u need it. i didnt get one for some reason sooo we had to 'make' our own.. that wasnt to much fun.. but o welll... you need to switch out the pilot/pivot bearing... uhm forget what it is ..lol one of the two..its whatever bearing that is in the center of the flywheel...then u need to switch out the throwout bearing... both are cake to switch..... now the hardest part was installing the tranny back up... cause it slides on the engine with two little poles that guide it snug, that was a pain in the ***.
but after it got done, we reconnected everything.... jacked up the rear of the car and made the car level.... checked and refilled the tranny with HONDA tranny fluid from the dealership. that is a must... i cant insist that more ... do not put some knock off brand or some other **** in ur tranny... goto the dealership... they have it on hand. tranny takes like 3.5 bottles of the stuff if u plan on flushing it all i bought 4 bottles and it was 13bucks.. no biggie. but honda tranny fluid is a must.
after that ...test it out.. make sure theres no chatter against the flywheel and your good to go... like i said i have the Extreme kit... (act) is the one rebelow the 6 & 4 pluc kits. AND let me tell you its like the best mod to date ive done to my car.. functionality wise. theres like 6 inches less of throw to the clutch... its not crazy stiff... its still pretty soft.. more 10x more responsive... its so easy to actually feel out where the clutch grabs, as oppossed to out stock mush imp: but let me remind you.. i have NO idea how hard it is with the engine in the car.. cause well... my engine was out cause i swap'd it for a new one cause i blew a hole threw the block last month, BUT i held the tranny in my hand... its like 40lbs... and hardly big..
edit oh and i dont recommend getting a new flywheel.. theres really no reason imo.. and i got mine off of ebay out of luck.. for DIRT cheap of what it goes for...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427439971
Old Sep 15, 2003
opto_isolator's Avatar
Heh - its a lot easier when you have the engine out of the car (as in your case)....Unless you have a lift there's no way you'll be getting the transaxle out from beneath the car....
Old Sep 15, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
thats not true , not at all...how do u think mine came out? with it still on?
honda.lioness
16
Feb 10, 2017 10:53 PM
Donahue
Sep 8, 2015 09:00 AM
Mucklow
Aug 22, 2015 06:28 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
