Cam gears and pulley
Old Aug 9, 2003
LnkinParkPunk's Avatar
LnkinParkPunk is an unknown quantity at this point
Hey does anyone know if the aem cam gears are the same for each model civic and how much hp and torque they give you and how much hp and torque a new pulley system will add?
Old Aug 9, 2003
straightridah03's Avatar
straightridah03 is an unknown quantity at this point
good question...i just bought a cam gear for my 02 civic lx (5-spd) and im having this shop put in on for me...from what i kno they add like 5 hp or something...lol...some guy on a forum said that cams give a little bit more throttle response and its a little faster in 1st and 2nd gear...it also sounds better when its idle. I think they make cams for civic 2001 above (dx,lx) and they have another set for the (ex) 2001 above...
Old Aug 9, 2003
ok thanks man
Old Aug 9, 2003
CapYoda's Avatar
Escaped Convict
cam gears are NOT bolt on power.
you wont get squat from putting them on. as far as I know.
pulleys? 1-2 hp? and most likely only at few specific point in the powercurve... basically, not worth it.
same goes for the cam gear on a lightly/medium modded civic. you dont need it unless you need to tune your engine's powercurve.
and as for yet, I haven't really seen an NA 7thgen that really needed a cam gear.
Old Aug 14, 2003
i just got my cam gear put on today...not bad...im thinking of getting pulleys...
Old Aug 14, 2003
CapYoda's Avatar
Escaped Convict
*rolleyes*
Old Aug 14, 2003
nongv's Avatar
nongv is an unknown quantity at this point
you'll still need to adjust the degree on the cam gear? if it is just set at 0 degree then you basically still have your stock cam gear on. to actually get the best degree is to dyno it at each degree to see which give more power. last time i heard was that it was best at -3 or -4 degree.
Old Aug 16, 2003
ur right...i must be dreaming then...i prolly imagined the hp i gained...LOL
Old Aug 16, 2003
kTxCiN's Avatar
Stage7
kTxCiN is an unknown quantity at this point
you can feel 1 or 2 hp?
Old Aug 17, 2003
i dont kno man...there isnt much to get it for ur cars performance unless u get a turbo...so u might as well get the little things...and eventaully they'll add up and give u wut u want
Old Aug 17, 2003
ImportRacer2123's Avatar
K20 Member
i think if i saved all the money i put into my car i would have more than enough for a K20 Swap and a Turbo :-\
7thgensurvivor
Aug 26, 2015 06:17 PM
CdnRD
Aug 21, 2015 11:42 PM
WaryDriver
Aug 16, 2015 11:22 AM
WaryDriver
Aug 8, 2015 05:08 PM
Ccoop87
Jul 9, 2015 03:26 PM
