HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
Thoughts on these lights.
Old Apr 28, 2014
FORMULA51's Avatar
newbie
FORMULA51 is an unknown quantity at this point
Here's what i'm looking at getting
http://www.carid.com/1999-honda-civi...-12130164.html
what are your thoughts and opinions on them? Go easy on me I'm new to the tuner scene. If theres a better option out there please let me know.
Old Apr 28, 2014
Poopies's Avatar
Super Moderator
Re: Thoughts on these lights.
Retrofitting a HID projector into your OEM housings is a more reliable option. I was considering those same lights until I went here. Best decision I've made in a while.
Old Apr 28, 2014
FORMULA51's Avatar
newbie
why is that a more reliable option?
Old Apr 28, 2014
Poopies's Avatar
Super Moderator
Your OEM lights are more durable, more water resistant when resealed correctly, and are aimed correctly. There's a reason a lot of the senior members still use theirs. Quality isn't usually cheap, unfortunately.
Old Apr 28, 2014
FORMULA51's Avatar
newbie
one of my issues is my light lens cover is faded and deteriorating. Thats why i'm still leaning to the full replacement. I didn't really think $180 on lights was all that cheap, as I never bothered even doing lights on my offroad vehicles as they get broken so much bouncing off rocks and trees and stuff.
Old Apr 28, 2014
GolNat's Avatar
Prelude Owner
Try restoring the lenses with a kit. I think you will be surprised.
Old Apr 28, 2014
Poopies's Avatar
Super Moderator
+1 to that. BTW, GolNat is the guy who finally convinced me to retrofit. My driver's side lens looks like someone j!zzed superglue on it for some reason, but other than that they are WAY clearer than they were last year before I restored them. I used the Rain-X restore kit.
Old Apr 29, 2014
FORMULA51's Avatar
newbie
I saw the restore kit. I wonder if it's better to just use it. I'm still iking the blue led lighting that those new lights have
Old Apr 29, 2014
FORMULA51's Avatar
newbie
those lights are aimed incorrectly aimed?
Old Apr 29, 2014
Poopies's Avatar
Super Moderator
Yes, and it's relatively cheap too. The blue lighting?
Huh?
Old Apr 29, 2014
GolNat's Avatar
Prelude Owner
You can't go wrong with a good retrofit!
Old May 1, 2014
FORMULA51's Avatar
newbie
Huh?
I meant to say if they're adjusted correctly by the honda adjustment screws they still aim badly due to faulty engineering?
Old May 1, 2014
Poopies's Avatar
Super Moderator
The retrofit kit? The left side was perfectly aimed from the start but my right headlight is slightly off target <---> because I screwed around with an adjustor before I put it back in; I'm too lazy to take it off and adjust it right now. Depending on the model/year, you should be able to AT LEAST aim up/down once the lights are reinstalled. Did that answer your question?
Old May 1, 2014
to sum up:
most aftermarket replacement lights with halo angel eyes put very little light and/or in the wrong places.
way better to install projectors that were actually well designed in the stock housing.
ah, most of then will fog when rains.
mine - light sucks and right side fogs.
but my stock ones were beaten, so i put them.
mrwhos
Aug 11, 2015 02:03 AM
RSJ
Jul 23, 2015 11:29 PM
sch2cm
Jul 21, 2015 09:58 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
mistermenphis22
Jul 13, 2015 04:43 PM
