HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
Morimoto 3Five ballasts
Old Jan 23, 2014
During the start of winter, I started having problems with my Morimoto 3Five ballasts from theretrofitsource.com. My passenger side ballast would fail to fire when I turned on my headlights (but would be alleviated by turning my lights off and on again), and I experienced some light flickering, as well. I e-mailed TRS about it, and here was their response:
Over the past several weeks we have been working non stop to study and correct the issue and have concluded on two necessary changes for the ballasts:
1) If you're experiencing a mis-firing bulb: We found that the magnetic core used in the igniter sometimes won't put out the necessary 16KV to create a strong enough arc, especially when cold.
Solution: The new standard igniter will be capable of producing up to 20,000 Volts. Rather than going with an externally mounted igniter because the existing ballast shell is too thin, we have opted to increase the ballast's thickness by 2mm to accommodate the massive igniter. It's like putting a V8 in place of a V6.
2) If you're experiencing a slight "flicker" - this is because the reaction time of the ballasts circuit board isn't fast enough to keep pace with the instability in the arc inside your HID bulbs.
They then put me on the waitlist for their new, upgraded Morimoto 3Five ballasts, which I just got in the mail today.
At a glance, there's not much of a difference, as far as aesthetics go. They are nearly identical, the only exception being the new ballasts being a few millimeters thicker. On the inside, there's apparently a new igniter/igniter capacitor that puts out more voltage than the old ones, as well as an upgraded chip to help it perform better. When I initially fired it up, the only thing I noticed was that the light did indeed stabilize faster. No fail-to-fire situations yet, but I've only fired 'em up twice since I installed the new ones.
So, why am I posting this up? The Morimoto retrofit is a popular choice among our community, and if you have some Morimoto ballasts that you received anywhere from 2011-2013 and are experiencing lighting issues, contact TRS right away, and they'll set you straight.
Old Jan 25, 2014
schollianmj's Avatar
schollianmj will become famous soon enoughschollianmj will become famous soon enough
Re: Morimoto 3Five ballasts
yea, Matt always takes care of his customers. Good guy to do business with.
Old Mar 10, 2014
GolNat's Avatar
Prelude Owner
Thanks for the info!!
I am starting to have problems with my driver side ballasts not lighting on the first start up. I will make sure to contact TRS.
Did they replace both of them of just the one you were having the issue with?
Old Mar 10, 2014
They sent me a brand new pair. All they ask in return is you cut the cords coming from the ballast and send then picture proof (with serial numbers in view for both). They hold you credit card information until then, and once you send the pic, they send you an email saying the got it and are deleting you cc info they stored
Old Mar 10, 2014
Poopies's Avatar
Super Moderator
Cool, now I want to figure out which ballasts I have!
TuRtLE714
Lighting
Jan 3, 2005 10:59 PM
BlueFlame
Lighting
Apr 2, 2004 12:22 PM
MangoEX
Jan 29, 2004 10:07 AM
Zzyzx
Jun 4, 2003 09:57 PM
klam
May 1, 2003 10:07 PM
