HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
Looking to switch to HIDs
Old May 3, 2012
enigmatic jc's Avatar
enigmatic jc is an unknown quantity at this point
hey guys, so i have a 2005 civic sedan se (i think a dx in USA) and i was looking into switching my headlights into hid. Would these be a good purchase for me?
http://www.xtralights.com/04-05honda...itpackage.aspx
Will there be anything else i would need to buy? will these fit into my car with no problems?
Thanks in advance
Old May 3, 2012
Artificial's Avatar
Artificial has a spectacular aura aboutArtificial has a spectacular aura aboutArtificial has a spectacular aura about
Re: Looking to switch to HIDs
Those are reflector housings, just like the stock ones. You need projector housings for HIDs.
Old May 3, 2012
If you wanna go HID, I'd definitely look into doing it "proper" (i.e. retrofit). You won't blind people, and you'll most likely spend less money in the long run
Old May 4, 2012
thanks for the replies guys, but i dont wanna do the retrofit...given that i know nothing about this stuff can you guys help me find what i would need to buy by providing me links to websites?
Old May 4, 2012
the reason I brought up the retrofit is because every time I see someone on the road with aftermarket HIDs in reflector housings, I wanna go up to their window and punch them in the face. Getting blinded by that **** is no fun, and I see it way more often than I'd really like to.
There's my 2 cents..
Old May 6, 2012
What do you guys think about these ones?
http://www.k2motor.com/04-05-honda-c...hts-black.html
anyone know how good the light output is? and if i did buy this i would need a hid kit correct? thanks
Old May 7, 2012
psu_lgt's Avatar
psu_lgt is an unknown quantity at this point
You're on the right track now. As mentioned before, you need projector housings. As far as light output, it will basically be the same with the oem bulbs. You will still need to purchase a HID kit
Old May 19, 2012
alright so i ended up deciding to do a retrofit...now which one of these kits would i need to buy?
http://www.theretrofitsource.com/pro...roducts_id=227
or
http://www.theretrofitsource.com/pro...roducts_id=237
Old May 20, 2012
the H1 projector has much better performance.
Old May 20, 2012
so this will work fine in my 05 civic right?
and which adapter plate and wire harness would i need to get?
Old May 20, 2012
yup it should, ive seen many members use them in 05 lights. the lo beam spot is 9006, and i believe they do have adapter plates in that size. same goes for wire harness. in canada you have drl, but it uses the separate hi beam and should work like normal. if you want the hid hi beam to work properly, you need to tap the + and - wires from the projector to the stock hi beam halogen bulb wires. that way you will have both halogen and hid hi beam.
Old May 20, 2012
thanks so much for the help but now my parents wont let me touch the stock headlights...so if i buy this : http://www.k2motor.com/04-05-honda-c...hts-black.html
would i still be able to retrofit it? and will the light output still be the same as if i was to do it in the stock lights?
Old May 21, 2012
yes exactly. i would look on ebay tho they are usually under $100 and they have all clear too instead of black. up to you on the color tho. the only bad thing about the aftermarkets is poor output from the reflector, which wont matter since you are installing projectors.
Old May 21, 2012
last question (hopefully) if i buy oem fog lights would i be able to retrofit these in? http://www.theretrofitsource.com/pro...roducts_id=249
Old May 22, 2012
possibly. ive seen it done, a few retrofit companies like hidillusionz.com has done em but the metal back is really hard to cut. maybe with a hole saw or dremel.
Old May 26, 2012
i want to get this kit
http://www.theretrofitsource.com/pro...roducts_id=141
but i just wanted to make sure that it would fit in the headlight housing (possibly with the gatling gun shroud)
Old May 26, 2012
tallal565's Avatar
tallal565 is an unknown quantity at this point
I have done a retrofit on my 2004 civic from the retrofitsource. i have the morimoto h1 projector with 5000k bulbs and they are beautiful. i used to have 4300k hid in my stock reflector. they werent bad at all but i wanted a clean light. i would suggest doing a retrofit. go to trs.com and they will tell you how. and why would you want to put projectors in OEM fogs. the beam on the OEM fogs are perfect and is made of high quality glass.
Old May 27, 2012
yea i have decided to do a retrofit with the mini's but i wanted to know if the fx-r stage 3 kit would fit and i might consider it if it does.
would you happen to have pics of your retrofit?
Old May 27, 2012
fx-r is a much better projector but requires lots of custom modding to fit. the mini just pops in using the stock bulb hole. mini h1 is good too, still better than halogen.
Old Jun 11, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Wow expensive. Just take out the stock Halogens from the stock headlights and put in two 55 watt HID systems from DDMtuning, one 9005 one 9006, about $96 shipped w/lifetime warranty. You'll be blinding people though, some people don't like that and get jealous/mad. But I've only been flashed a few times with mine in the stock reflective housings after 1.5 years of having them. Some reflective housings are worse than others though.
Old Jun 22, 2012
so i finally got the retrofit done by a local guy...he's known as linuxglobal on hidplanet.com
i ended up using my stock headlight housing and im happy how they turned out...i still havent got a chance to get output shots yet because im working overnights so i get no chance to
Old Jun 25, 2012
output shots
lo beam
hi beam
MamaBear2015
49
Sep 29, 2015 01:12 PM
junkyardguy
Sep 2, 2015 06:07 PM
mhsmom
Aug 31, 2015 10:45 PM
Blazz
Aug 30, 2015 11:07 PM
dtdoyle
25
Aug 30, 2015 06:57 PM
