HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
Blowing fuses
Old Nov 4, 2011
Shift-E's Avatar
That Dude with the Questions
Exclamation Blowing fuses
So, as some of you know, my cousin got some 10k (looked more like 8k) HID's from DDM with a relay harness for his Elantra. I know about DDM not being the best, and how they lie about the actual heat of their lights (hence 10k=8k) and the weakness of their harness.
Here's the problem. When we plugged it all in, the lights didn't work. We couldn't figure it out. Then we realized that both the left and right headlamp fuses blew. We replaced the fuses and tried again with one light and it worked, but as soon as we plugged the second light in the fuses blew again. Se we replaced the fuses a second time and are now running the HID's off of the stock relay harness and they seem to be doing fine, but we don't want to keep it that way for long.
What would cause something like this to happen?
Old Nov 4, 2011
MindBomber's Avatar
Live for the Twisties
Re: Blowing fuses
KDM, dats da problem
I'm no help..
Old Nov 4, 2011
Shift-E's Avatar
Re: Blowing fuses
Oh KDM... they're so popular these days, so very cheap.
Old Nov 4, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: Blowing fuses
A short in your system, most likely from a faulty relay.
Most often you get a short when a power line hits a ground line, causing it to short
Old Nov 4, 2011
Shift-E's Avatar
Re: Blowing fuses
Thats what i was thinking, since we had the same issue with DarkSouljurs relay harness. But that made the fuse on the relay harness blow, not the 2 fuses in the fuse box. So I was wondering if maybe theres something else in the equation that im missing. I'll have to double check the wiring harness's connections and see if theres any factory defects.
Old Nov 4, 2011
Re: Blowing fuses
or the wiring is too thin and cannot support the startup ballast draw. most aftermarket harness are terribly made.
Old Nov 5, 2011
Shift-E's Avatar
Re: Blowing fuses
So you think I should make one for him?
Whats the problem if I kept them without the wiring harness?
Old Nov 5, 2011
Re: Blowing fuses
melted stock wiring, possibly car fire.
Old Nov 5, 2011
Shift-E's Avatar
Re: Blowing fuses
He had other HIDs in there for a while before, but one of the ballasts went bad. I don't think he had any problems with them before though?
Old Nov 13, 2011
sl33pyriceboi's Avatar
Re: Blowing fuses
Any wiring harness u buy online are really shitty. They use 16-18 awg wire. And I've disected both DDM and TRS (the retrofit source) wiring harnesses. Same cheap chit.
A proper wiring harness needs to use at 12 awg (or as least 14awg) wire.
Check if u have the pins on the replay hooked up properly
And is the fuse on the harness blowing or the fuse on the car blowing?
Old Nov 13, 2011
Shift-E's Avatar
Re: Blowing fuses
The fuses in the car.
Old Nov 15, 2011
Re: Blowing fuses
im willing to bet the wires u plugged in to the headlight socket is shorting.
take off the wiring harness, plug ur halogen bulbs back in...is it sitll blowing the fuse now?
Old Nov 15, 2011
Shift-E's Avatar
Re: Blowing fuses
No, but he's running the HID's now without the wiring harness and no fuses are blowing. It has something to do with the wiring harness I'm thinking.. But if it was the wiring harness, then wouldn't it be the fuse on the harness blowing? I dunno. I don't think he's having any troubles right now without the harness. He ran HID's before without it and he was fine, though i think his ballasts got F'd up from something.
JetsterDajet
Aug 16, 2015 01:56 PM
adamdrives
15
Aug 8, 2015 08:53 PM
exiled1
Aug 8, 2015 06:09 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
