West Alaska, Arizona, Colorado, Hawaii, Idaho, Montana, Nevada, New Mexico, Oregon, Utah, Washington, Wyoming
Honda Starting Problem
Old Jun 5, 2010
lionel_lampkin's Avatar
lionel_lampkin is an unknown quantity at this point
Honda starting is unpredictable. I drove from work and made a stop, turn off the car, returned to the car, tried to start the car, it turned over strong, but it wouldn't start. I let set for a few minutes and it lit back up. Got it home and it repeated the same thing.
Can some one advise me on this issue. Thank you!
Old Jun 6, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Honda Starting Problem
Is it getting fuel and spark? Those are two important things to check. When is the last time you have done a tune up?
Old Jun 6, 2010
Thank you for you response; I just gave it a tune up about three + months ago, car has been running rough of late very bad gas mileage and shakes when idling in neutral. This problem of not starting after driven for a while is a new one. Trying to nip it in the bud before I or my wife get stuck some where! Thanks again.
Old Jul 21, 2010
Jenni's Avatar
Jenni is an unknown quantity at this point
Random thought... did you get your battery checked already? Any dead cells? And if no dead cells, can anyone take a multimeter to your starter and test to make sure it's properly functioning? My fiancee's Maxima needed his starter replaced several times because the solenoid was the issue each time. Look into that if you haven't already
Old Jul 26, 2010
padoke's Avatar
padoke is an unknown quantity at this point
If it's still not starting, you might want to have a compression test done. Check your spark plugs and see if you're getting spark from them. You might want to remove your distributor cap and remove the Igintion Control Module (ICM), and your Ignition Coil, and take it your local auto parts store and have them run a diagnostic check on them.
Jon-Ohio
Jun 30, 2018 08:10 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
