1st - 5th Gen Do It Yourself Articles Look here for anything and everything you want to do yourself for your Civic and save money! If you can't find what you were looking for here, what about writing an article yourself? Hep appreciated! Questions on how to do are better suited in the Mechanical issues section
Solution - Frozen Spindle Nut Solution
Old Apr 16, 2013
JanThorCro's Avatar
JanThorCro will become famous soon enough
I'll confess I'm only here when I'm looking for information or sharing it. Today I'm sharing.
Last year I replaced the passengers side drive shaft on my 1985 Civc named "Jane". We were both happier as a result and it was a snap to do. I recently got one for the drivers side because of the lovely, tic, tic, tic...
Well the Spindle Nut was frozen to the tune of 1 broken breaker bar, 2 broken ratchets and another abused breaker bar (10 degree twist). The other side came off with a ratcheting 2' long 1/2 drive craftsman. Drivers side busted that puppy in no time. Of coarse I was using a pipe and an extender for maximum torque. Even used some heat, but not to serious.
So I eventually had the idea to drill holes into the nut and chisel the P.I.T.A. off. I did it with a cordless drill with partially charged batteries. So if you own a drill with a cord on it even easier. Not even 10 minutes drilling. I used 1\8", 5\32", and 3\16" drill bits.
Worked slicker than snot. Just put some masking tape around the drill bit to let you know when you have gone far enough... Use the new nut to set the depth of drilling.
Last edited by sdaidoji; Nov 30, 2013 at 09:42 AM. Reason: Added Solution in title
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Bruce2
Sep 27, 2015 08:45 PM
260000milesgoal
Sep 25, 2015 07:41 PM
