Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Swap D15B How to?
Old Jul 14, 2011
Civicboy420's Avatar
Civicboy420 is an unknown quantity at this point
Swap D15B How to?
Hey I need to swap out my D15B with the same motor from my 89 civic dx and I was wondering if someone has a how to on this site? Thanks
Old Dec 31, 2011
rrait's Avatar
rrait is an unknown quantity at this point
Re: Swap D15B How to?
Easy -
1. Unplug everything - wires, hoses, power steering, A/C etc.
2. Unbolt the axle bolts - pull out axles.
3. Disconnect exhaust manifold from muffler.
4. Unbolt Engine and transmission mounts - pull out the engine
Take new engine and do it in order 4.3.2.1
PS. You probably will have a lot of problems disconnecting all vacum and gas hoses. Rust remover or dissolvant or some other kind of lubrication will be needed.
YOu can also google civic ed repair manual, there is 1265page version for civic eg. So there should also be one for ed.
Old Jun 3, 2012
JLP's Avatar
JLP
JLP is an unknown quantity at this point
Hey do I need a MPIF harness out of a 88-91 si to put in a D15B Vtec OBD1 in to my 90 DX hatch can I use my harness or can I use one from an eg I all ready have the motor, ecu and the OBDO to OBD1 jumper harness if any one can help me that would be great
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
