Key in 2nd pos. nothing turns on..
Old Apr 23, 2013
Mike91W's Avatar
Mike91W is an unknown quantity at this point
Exclamation Key in 2nd pos. nothing turns on..
So I went to turn my car on the other day and it just started for a few seconds and died.. kept trying to start it and noticed none of the dash lights were turning on and the fuel pump not priming but i can wiggle it in 2nd pos and get it working... Anyway im assuming that its the ignition switch and was wondering if theres a way to bypass the 2nd pos with a switch?? 94 civic si coupe
Old Apr 23, 2013
Re: Key in 2nd pos. nothing turns on..
but i can wiggle it in 2nd pos and get it working.... Anyway im assuming that its the ignition switch
Sounds like you just need to buy an ignition switch.
was wondering if theres a way to bypass .....
..... with a switch??
Yes.
Old Apr 25, 2013
Mike91W's Avatar
Right I was figuring it was that. question is how difficult is it to replace the switch? Do I replace the whole wiring for it or just the tumbler? and my question basically was what wires do i use to put a switch on?
Old Apr 25, 2013
I looked in the catalog, Honda sells the column lock assembly WITH the ignition switch as a unit, complete with a couple new keys.
DangerZone appears to sell the same type of deal.
You can look those up for yourself.
Seems that you can't buy JUST the electrical switch portion by itself, like you can for newer cars.
But if you are really itching to try, take yours apart and see if the electrical switch section will match up with something from a newer car. Just a thought. Probably best to just do it the right way.
Someone with a bit of electrical (common sense) knowledge and a wiring diagram can do it.
Gotta know what you are doing though, gotta be safe about it. Don't want to be responsible for burning the car to the freekin' ground because of a hacked wiring job with underrated switches.
Old Apr 26, 2013
Mike91W's Avatar
Looks like you can get just the wires. so is it the harness itself i need or do i need the tumbler too?
Old Apr 26, 2013
Link? Pics?
I couldn't find it that way (elec. switch and wire by itself) when I looked the other day. At least not for a 94.
If you can get the switch -- by itself -- without the column lock assembly and it is actually right for the car, then go for it.
NOTE: I'm in the US, we did not get a 2 door Si. We had a 3 door hatch Si. Canada might be way different.
Old Apr 27, 2013
Mike91W's Avatar
Yeah mines the canadian si. but the link i found was for ebay. http://www.ebay.com/itm/1992-93-94-1995-HONDA-CIVIC-IGNITION-SWITCH-WIRING-HARNESS-5-SPEED-/230966855546?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c6b2877a&vxp=mtr
Old Apr 27, 2013
Hell yeah, that would probably be a lot simpler to replace than the whole column lock.
I'd go for it.
Old May 16, 2013
Mike91W's Avatar
yup thats what it was. thanks for the help again ezone!! you rock man
CarStuff
Dec 6, 2020 12:52 PM
Blazz
May 25, 2015 10:56 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
civic_gt
Apr 19, 2015 08:15 AM
