94 civic ex coup problems
Old Apr 20, 2011
skeez94civic's Avatar
skeez94civic is an unknown quantity at this point
Windshield wipers work some of the time. U can hear it kick on but nothing happens. U have to play around with the switch till the wipers work. my speedometer will stick at about 40 to 45 and about 60 to 65 and my rpm gauge will get stuck as well. Any suggestions??? And also i need to kno what kind of possibilities i have with a little SOHC VTECH? Dont kno where to start for this so im tryin here first. This is my first honda and i need major help.
Last edited by skeez94civic; Apr 20, 2011 at 09:15 PM. Reason: left a couple of things out
Old Apr 21, 2011
lazlong's Avatar
Re: 94 civic ex coup problems
1. Either the switch is bad or the connector/wire is bad. Take the cover off the steering column and see if it's connected securely or has bad/crimped wires.
2. Probably need a new speedo cable. Although it could be the gauge itself, which is replaceable without having to replace the entire cluster. I recommend this place as a good place to start for that gauge: http://www.picknpull.com/default.aspx and here for new parts: http://www.hondapartscheap.com/southbay/jsp/home.jsp
3. You already have a Z6 so for more power you could turbo or swap to a DOHC (B16, B18, B20) or go for the ultimate swap- K20 (comes in the RSX and new Civics).
ghondavic
Transmission
Apr 12, 2017 09:37 PM
Civicman92296
Apr 23, 2015 09:22 PM
coupeciv
Exterior
Apr 23, 2015 06:48 AM
lilbluecivic
Nov 7, 2001 06:49 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
