No radio harness plug, just loose wires coming from the dash...pls help
i just picked up a 95 civic last night and i was just about to install my deck. I pulled out the old one that was in there, BUT there is no harness... the guy had his deck harness wired straight to the wires, w/ no harness in the middle. ( probably got broken into and somebody clipped it right off)... anyway, i was wondering if there is like a color chart for the 95 civic wiring that i can use to wire it up correctly since i can't just plug it right in... i'm posting because i couldn't find one... thought this would be a 1 minute job because im putting in the deck from my integra, so it would plug right in...FML
Re: No radio harness plug, just loose wires coming from the dash...pls help
the metra harness is available at best buy.it is the 16 pin harness and it comes with a chart for the wiring colors.you can get the color chart for the wires in the dash from any honda dealer.tell them to look up the service news for part# ae-94t91063f01
Here you go if you need more help let me know I can guide you threw what wire is what color and all on your new head unit.
http://www.the12volt.com/installbay/....asp~TID~86090
your best bet would be if you have a junk yard near you, go a snip the plug out of one and wire it back to your car. Then, just plug-n-go.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
tkcne
Apr 18, 2015 02:33 AM
