95 Civic LX not charging??HELP!!
Old Dec 2, 2007
Blastem's Avatar
Blastem is an unknown quantity at this point
Hello,
New to the forums here. My question is this. I have a 1995 Civic LX that is only showing 12.2 V at idle and 12.5 at 3500 rpm. Its a new battery and the third new alternator in the past 2 months. Could I have a problem in the wire harness? If so can I jump around the harness? What wires (color) should I be looking at to send and return current to the alternator? I did do a search on here and some say that pulling the positive battery terminal could cause damage while the car is running and others say its a way to see if the alternator is working. Could this also be a computer problem?? I am at my wits end with this and cannot seem to solve this problem! This is my day to day run around car so no modifications have been made as far as I know its all stock.
Any HELP would very greatly appreciated!!!!
Old Dec 24, 2007
Devin Eaton's Avatar
Devin Eaton is an unknown quantity at this point
Re: 95 Civic LX not charging??HELP!!
First I would check in the fuse box for blown fuses if any then replace then find which one is your ignition and alternator and try a different one. I had the same thing happen luckily mine was only a fuse. If its still messed up then check out ur wire harnes good luck.
Old Jan 22, 2008
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
any conclusion/solution to this?
CarStuff
Dec 6, 2020 12:52 PM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
tylerginevan
Apr 27, 2015 12:29 PM
alexkharden
Apr 23, 2015 07:13 PM
SSMatey
Apr 13, 2015 06:09 PM
