Cold delayed start
Old Nov 2, 2019
JHOOD94's Avatar
KnowsNada
JHOOD94 is an unknown quantity at this point
Cold delayed start
So recently my Civic has began to have several issues. In the beginning I could drive the car without any problems. Then three weeks ago the car would become sluggish. I would coast to a stop or drop down to a lower gear and the car would either: stutter and drop to 300-800 rpm, stall while in motion or a stop light, or stall aftet a series of backfires.
So thanks to this forum I went through as many suggestions from checking for a vacuum leak to checking and correcting the fuel to air ratio. Thank you all for that. I have not had any more issues with that once the engine is warmed up.
But now for two weeks the car is struggling to start after cooling overnight or after a couple of hours. I turn the key and the car cranks, but doesn't turn over. I have to turn the key several times to get it to turn over. And when it starts the idle is so rough that I have to press the gas pedal and run the car at 2,000 rpm or higher to get it to warm without stalling. Several times the car has had a backfire.
I have replaced the valve cover gasket, spark plugs, distributor, spark plug wires, oil filter and oil, coolant, and checked for fuel. But the problem persists. Any ideas? Thank you in advance for everything.
Old Nov 2, 2019
GolNat's Avatar
Prelude Owner
Re: Cold delayed start
CEL on?
Old Nov 2, 2019
mac25's Avatar
Dr Krieger of Modification
-temperture sensor
-air in coolant
-idle adjustment screw
Watch "How to solve honda idle problems", bu Eric the car guy, on youtube.
Old Nov 2, 2019
JHOOD94's Avatar
KnowsNada
Originally Posted by GolNat
CEL on?
So I am slowly plugging along on replacing, cleaning, or upgrading the necessary parts to clear the CEL's. But yes there is. As of right now now, the car is showing #6 which is because I broke the wire to the Engine Coolant Temperature sensor.
I have not been able to figure out how to read all CEL's, because the light will only show one at a time. Any suggestions? It is OBO1.
Old Nov 2, 2019
JHOOD94's Avatar
KnowsNada
And I will go look that video up tonight. Thank you.
Hunter Freas
Mar 27, 2016 11:07 AM
What_It_Do
30
Nov 24, 2015 08:07 PM
What_It_Do
Jan 8, 2015 04:22 PM
D16Y86
Sep 21, 2012 08:37 PM
dsmith227
Jan 8, 2012 10:49 PM
