Electronic Air Control Valve.
Old May 24, 2017
leiniedude's Avatar
leiniedude will become famous soon enoughleiniedude will become famous soon enough
Hi all, I had been having starting issues with my 1991 Civic DX,1.5 dual point engine. It would start right up but die just as fast. It would run rough with my foot in the throttle though. My Haynes manual said to pull the flasher fuse out of the main fuse box for 10 seconds, which I did. It worked! For about a week.Digging deeper the EACV seemed to be the problem, I removed it and put the meter on it. 8 to 15 ohms was the number I needed. No dice. I tried to jump it from the battery as this is basically a small pump. Nothing. I bought a replacement from Auto Zone for $212 bucks. A pretty easy replacement job. She now runs like a champ again. I hope this will help someone in the future. You have a great Forum here, thanks, Mike.
Old May 25, 2017
mac25's Avatar
Dr Krieger of Modification
Re: Electronic Air Control Valve.
Thank you for the info. =D rep added.
Old May 28, 2017
leiniedude's Avatar
Hi mac25, not sure what the D rep is all about, but looking at your avatar it must be a good thing. Thanks. Say, I forgot to mention in my original post that I did get the 14 flashes for code 14 when checking the computer under the passenger floor mat. Take care, Mike.
