seafoam?
Old May 5, 2016
91LXdriver's Avatar
91LXdriver is an unknown quantity at this point
seafoam?
Has any one seafoamed their honda, I have a lx sedan D15B2, auto,, and Im getting a lot of carbon out my tail pipe, would seafoaming help this or could it cause more problems,,, This is a vehicle with 189000, miles on it
Old May 5, 2016
Re: seafoam?
I would not, not without a good reason, and your stated reason does not sound good or worthwhile to me.
There will always be carbon in the exhaust.
But you're probably gonna do it anyway.
Old May 6, 2016
mac25's Avatar
Dr Krieger of Modification
Re: seafoam?
Seafoam is to de-carb cylinder walls, piston heads and valves.
You would not be able to see this from the tail pipe since the carbon cooks into the metal (that's why you should remove it).
What you are most likely seeing is burning oil.
Do you see dark or blue smoke? (If so that is common on old engines and you are burning oil).
Old May 6, 2016
91LXdriver's Avatar
Re: seafoam?
a little blue smoke once in a while when cold start, but stops when engine warms up, figure maybe valve seals
Old May 6, 2016
91LXdriver's Avatar
Re: seafoam?
I understand there always gonna be carbon in tail pipe, but it shouldnt blow out of tail pipe and leave carbon on drive way and if you back up to within a foot of wall it leaves carbon on wall on cold start up..
Old May 6, 2016
Re: seafoam?
If it is sooty water that blows out, it could be normal.
An engine would be running rich while it is cold (that is normal until engine is fully warmed up), that could contribute to carbon you see.
If you rev up the cold engine you can probably see black smoke. Still normal.
So far these seem like typical things an engine can do.
Especially an older engine/older car.
Maybe your catalytic converter is nonexistent?
Does your car have to pass an emissions test where you live?
The bottom section of the garage door in my bay at work sometimes gets covered in soot. I try to clean it off a couple times a year.
Old May 7, 2016
91LXdriver's Avatar
Re: seafoam?
well it is 25 yrs old, and as far as I can its original engine,, No dont have to worry about passing emissions test so far any ways,, LOL
Old May 9, 2016
DJPurdue's Avatar
DJPurdue is an unknown quantity at this point
Re: seafoam?
Try this link and decide for yourself if seafoam is the right thing for your car. In my opinion ChrisFix does good videos and they are reasonably objective.
Either way let us know how it turned out for you. All the best.
g_force58
Jan 7, 2016 07:03 AM
nicholastiew
Dec 22, 2015 06:35 PM
MindBomber
Engine Swaps
Mar 19, 2011 08:31 PM
MindBomber
crashedout78
Jan 28, 2002 03:02 AM
