95 1.5 non vtec hard starting Civic
Old Mar 22, 2016
woodsjd1's Avatar
woodsjd1 is an unknown quantity at this point
symptoms: long, hard starting when cold, then when it does seem to pick
up gas it sputters and tries to quit but I can keep pedaling the
gas and it eventually picks up and smooths out
idle is fast even with cable disconnected....timing is correct
what I've done: switched out IACV with another I had, but both could be bad
switched out throttle body w/all sensors (junk yard)
question?? how do I test the IACV?? I unplugged it while @ OT and idle
slowed a little and I heard something activate
OR?? any other ideas??
thanks
Old Mar 23, 2016
woodsjd1's Avatar
I have a 95 Civic 1.5 non vtec that recently developed some hard starting issues...at first I thought it was a frozen fuel line (what it acted like)...treated fuel, changed filter, changed fuel pump, changed throttle body with all sensors on it..no luck.......engine cranks longer than normal before it eventually does start, and when it does it acts like its starving for fuel... I can pump the pedal and in a few seconds it will pick up fuel and smooth out....after warmup it idles faster than normal...(would guess around 900 or so RPM)...timing is correct, and throttle cable is adjusted all the way out....ideas??
thanks
Old Mar 23, 2016
Poopies's Avatar
Super Moderator
Re: 95 1.5 non vtec hard starting Civic
Is it possible that the fuel injectors could be dirty? A bottle of Techron (or additive if your choice) is a lot cheaper than firing the parts cannon!
Also merged and moved the threads.
R Steele
Oct 22, 2015 05:09 AM
MyOtherRideIsBritney
Bolt-on Engine Performance
Jan 1, 2002 12:58 PM
CrEePin01CiViC
Jan 1, 2002 11:29 AM
AnotherDopeStyle
Dec 28, 2001 05:26 PM
1stcivic
Nov 18, 2001 09:17 PM
