My Rear Window Defroster does not work
Old Dec 10, 2015
Wild Cranker's Avatar
Wild Cranker is an unknown quantity at this point
.. but the light for it comes on to be working.
Why?
Old Dec 10, 2015
Re: My Rear Window Defroster does not work
Why?
Because it's broke?
Do you own a volt meter or test light yet?
Old Dec 10, 2015
Originally Posted by ezone
Because it's broke?
I have both, yes.
Old Dec 10, 2015
What can you do with a volt meter OR test light to check your rear defogger?
Old Dec 10, 2015
I have no idea.
Old Dec 10, 2015
Overall Power Test: The first thing you need to find out is whether your defroster grid is geting power at all. Sometimes old wiring or a blown fuse can cause a complete disconnect. To test this, you can use either the defroster test lamp or an automotive circuit tester. Disconnect both wires from the either side of the defroster grid. Touch or clip one end of your tester to each of these wires - if the light comes on, you have power. If it doesn't, you should check your fuse and replace a bad or questionable fuse if you're not sure. *Note: Be sure you have the rear defroster switch on and the key turned to the ON position when you test.
Read up:
autorepair.about.com/od/troubleshooting/ss/My-Rear-Defroster-doesnt-work.
Old Dec 10, 2015
CraigW's Avatar
Do not manhandle the connectors.
jbrown59
Dec 8, 2015 01:21 AM
pare_john
Dec 7, 2015 02:31 PM
Civility
Dec 6, 2015 06:21 PM
Techno
Dec 2, 2015 11:23 PM
jferristx
Lighting
Nov 28, 2015 12:03 PM
