95 civic ex with d16y7 engine problems
Old Mar 8, 2015
Pkhocog's Avatar
Pkhocog is an unknown quantity at this point
I just bought a 95 civic ex with a d16y7 motor... I've serched and serched for answers! The car is bogging out won't past 2300 RPM's on 4 gear it feels like it's being restricted from power... Brand new fuel filter, new spark plugs and wires new distributor new TPS sensor and still getting the same results the car starts up no problem idles fine no CEL! I looked into the ECU too and it has a PO6 ecu witch is obd1 and I have a d16y7 witch is a 00 model and a obd2... my harness is obd1 this set up was on the car when I got it... I am down to nothing now don't know what's next... Anyone out there that might help me out
Old Mar 8, 2015
Hensinger2010's Avatar
Meh...
Hensinger2010 will become famous soon enough
Re: 95 civic ex with d16y7 engine problems
probably the guys in the fifth gen forum not the 7th.... maybe 6th but even that's stretching it
Old Mar 8, 2015
Pkhocog's Avatar
95 ex with D16y7 motor help
Okay i just bought a 95 civic ex with a D16y7 motor... It's running starts up no problem... No smoke no leaks.... The problem is it Boggs out no power on wide open throttle! Changed out spark plugs and wires all brand new too changed out TPS sensor change out fuel filter... Fuel pump wines up on the on position so it's good have a fuel pressure gauge and I'm reading 50 psi... Would the ecu be a problem? I have a PO6 ecu running a d16y7 I think the year is a 2000 model so it's obd2 and I have a obd1 ecu and harness... Can someone help me out?
Old Mar 8, 2015
Re: 95 ex with D16y7 motor help
Does it still have a catalytic converter in the exhaust?
Exhaust backpressure check?
Old Mar 8, 2015
Pkhocog's Avatar
I have a full catback exhust... The thing I wanna know also is the ecu and motor I got a PO6 and a y7 engine is that fine or would I have to jump it to a OBD2 ecu?
Old Mar 8, 2015
That didn't answer my question:
A clogged cat can cause the symptom you described. That's why I suggest you do an
That I cannot answer.
I figure it probably ran ok when someone first got it all set up, so why doesn't it run ok now?
Old Mar 8, 2015
Pkhocog's Avatar
I have no cat... How to check I'm my ecu is on limp mode?
Old Mar 8, 2015
moved to correct section and merged to the other thread
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
smmahan
Apr 15, 2015 08:17 PM
dooner24
Apr 14, 2015 07:51 PM
