idle issues and bogs out once warmed up
Old Feb 13, 2015
nosoulsince94's Avatar
nosoulsince94 is an unknown quantity at this point
So I recently bought a 1993 civic si coupe 1.6l vtec and it had the engine rebuilt and was sold to my friend prior to me. It was only driven a month and a half and then sat for four months. The first time I drove it we had to jump start it and it started no problem, I drove it to the gas station and put oil and gas in it so I could drive it home. Went to go start it and didn't start. So I got a couple jump starts and went to leave and the car died. So I had it towed and I've been working on it a bit at home since. I changed the fuel filter and all the spark plugs fully charged the battery and changed the connectors to the battery terminals. Now it idles well when it is warming up it even drives well to, and as soon as its warm the engine almost dies out and when I put the clutch in rpms drop to about 500 and it doesn't idle stable it bounces between 700 and 1100 rpm. And once my engine is completely warm I try to drive it and it has lots of hesitation and if I floor it even at idle it bogs out.
Old Feb 13, 2015
Poopies's Avatar
Super Moderator
Re: idle issues and bogs out once warmed up
Clean the Idle Air Control Valve? The idle is affected when you depress the clutch?
Old Feb 13, 2015
Not to much I can hear a tiny difference when I release the clutch. I dropped the car off at a mechanics so he can run diagnostics and just to fix he problems with the engine , becuause I am not to mechanically inclined.
Old Aug 20, 2015
kalhens90's Avatar
kalhens90 is an unknown quantity at this point
Did you ever figure out what the problem was, I'm buying a 1994 civic that has he same issues, owner told me its the probably the tps?
mikemc422
Aug 9, 2018 05:41 PM
Allecr3
May 22, 2015 01:24 PM
crowtoo
May 11, 2015 06:50 PM
Ninetyatecivic
May 9, 2015 07:48 PM
1stcivic
Nov 18, 2001 09:17 PM
