90 Hatchback door dash light
Old Nov 29, 2014
wfuentes's Avatar
wfuentes is an unknown quantity at this point
Hello. I'm having an issue with my dash light for my door. It does not turn off. Checked doors and they are not open. Help! Thanks in advance.
Old Nov 29, 2014
Re: 90 Hatchback door dash light
Open door.
Locate jamb switch.
Push switch.
Does the warning light go out?
Old Nov 29, 2014
wfuentes's Avatar
No it does not.
Old Nov 29, 2014
Wiring diagram looks like both doors will operate the same door ajar light on the dash, so either side could be at fault......but I look further in the diagrams..... Each door uses a switch inside the latch that operates the auto-shoulder belts, and those tie in to the light on the dash.....
This is getting confusing here since I can't actually see the car and have several versions of diagrams to choose from.
Does this car have an individual external switch in each door jamb?
Unplug each one to see if the light goes out.
Does the alternator light work?
Is the alternator light staying on too?
Brake warning light staying on too?
Old Nov 30, 2014
wfuentes's Avatar
I have the Hb with no power options. The alternator light is not on. I even tried switching the door lock switches.
Old Nov 30, 2014
Jamb switches or latch switches? I'm still not sure which the car is equipped with here.
Did you swap the switches, or just try it with both removed/unplugged?
I mean, if one is bad and causing this problem and you just swapped them, it would still be bad and keep the light on no matter which door it's on.
I'd remove and unplug them to make sure.
If no joy,
I'd probably unplug the control unit for the auto-shoulder belts next and see what happens.
Then I might pull the cluster and install my fault finder on the single wire that operates the light, and use that tool to track down where in the car that wire is contacting ground at.
voblak2
20
May 4, 2023 02:08 PM
MamaBear2015
May 3, 2015 02:17 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
twtron
Apr 17, 2015 12:09 AM
SSMatey
Apr 13, 2015 06:09 PM
