Can't Fill Gas Tank
Old Mar 21, 2014
Spartyof83's Avatar
Spartyof83 is an unknown quantity at this point
Can't Fill Gas Tank
I have a 2005 Civic SE. For the last week I can't seem to put more than a couple of dollars worth of gas in the tank at a time. Doesn't matter what gas station I use, it seems to clearly be an issue with the car. Anyone know what it may be or has had this problem as well?
Old Mar 21, 2014
Poopies's Avatar
Super Moderator
Re: Can't Fill Gas Tank
You should be more specific: how many miles have you gone through in the current tank when you fill up? Is it the nozzle's automatic shutoff thing or can you physically not put anymore gas in it? You can get around the auto shutoff if you hold the trigger lightly.
Old Mar 21, 2014
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
you could try not sticking the nozzle all the way into the car. pull it out a few inches and see if you can put any more in there.
Old Mar 21, 2014
I'll guess.....
"Canister Vent Shut valve" stuck closed, or... maybe frozen water in the vent hose (depending on the temperatures there), or some other obstruction to the tanks' vent system.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
jessica19699
Jul 29, 2015 05:51 AM
shaejb15
Jul 27, 2015 03:48 PM
jody501
Jul 10, 2015 11:01 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
