temp gauge on 95 civic?
Old Mar 4, 2014
velozp's Avatar
velozp is an unknown quantity at this point
Hi guys I have had my 95 civic LX for about a year. It has 158,000 and runs great. I have noticed since I bought the car the dash temp gauge does not read in the middle as my 98 does when its warmed up. its between the very bottem and middle. I do have a leaky radiator in the bottom right lower corner and I have to add some antifreeze about once a month to the reservoir. I plan on a napa radiator next week. Will this leaky radiator cause the temp to be low? The heat is good and I just had a honda TB and WP installed as part of maitanance. And it looks like the stock theromstat should be 170 degree? Any thoughts are appreciated.
Old Mar 4, 2014
mikey1's Avatar
Re: temp gauge on 95 civic?
over cooling is normally a thermostat fault, that is assuming it really is over cooling and your temp guage is accurate
if so, i would replace your thermostat with an oem honda thermostat
Old Mar 4, 2014
You cannot rely on the gauge for accuracy.
Old Apr 17, 2014
J-Master Flex's Avatar
J-Master Flex is an unknown quantity at this point
It probably just has an aftermarket thermostat in it with a bypass valve on it, so a little extra coolant flows through. A leaky radiator wouldn't lead to under-heating, but typically will cause the exact opposite. Definitely get that taken care of ASAP.
Mine has one of these thermostats, and my temp gauge typically sits at about 1/3 of the way.
Old Apr 17, 2014
CraigW's Avatar
Older Japanese temp gauges always read about there (and drove 95 Civics at a job I had for 2 years)
On later models they made them more towards centered.
Xuhme
21
Aug 7, 2023 03:40 PM
tylerginevan
Apr 27, 2015 12:29 PM
cooldan1
Apr 23, 2015 10:49 AM
fordfocussucks
Nov 6, 2001 03:16 PM
