95 ex with d16y7 idle probem
Old Jan 24, 2014
dravenlee06's Avatar
dravenlee06 is an unknown quantity at this point
Ok I have a 95 ex with a d16y7 the problem I'm having is the idle surges from 1k to 2k codes say iacv and barometric sensor changed the iacv and checked sensor, and I still can't find the problem. I've also changed tps map sensor. I thought maybe intake gasket leak, but when I start the car the idle will go to to like 3 grand and hold there for like 1 or2 mins then starts to surge again
Old Jan 25, 2014
Re: 95 ex with d16y7 idle probem
Figure out the IAC code, along with why it idles far too fast first.
IAC, FICV, whatever it has that controls fast idle.
Vacuum leaks.
Once you solve that and get the idle speed down to where it should be, the surging should stop.
Old Feb 19, 2014
new_guy26's Avatar
new_guy26 is an unknown quantity at this point
Its possibly an EGR delete.. my 95 does the same thing.. once it warms up it idles great tho..
SimpleUser
Apr 24, 2021 02:54 AM
Monty022581
Aug 31, 2015 08:32 AM
WaryDriver
Aug 22, 2015 06:50 PM
napkins
Aug 12, 2015 04:20 PM
