95 civic 1.6 mt wont start or crank HELP!!!
tested batt it is good tested starter its good checked fuses they are good can push start butt turn key no click from starter it is like i did not push in the clutch pedal what gives can anyone help or have any solutions
Re: 95 civic 1.6 mt wont start or crank HELP!!!
Is there some small pieces of crumbled rubber on the floor under the pedals?
Or a hard rubber disc about the size of a dime?
See if the rubber bumper pad came off of the clutch pedal where the starter interlock switch meets it.
Not from your car but I found a pic with the general idea, see the red arrow for "switch A":
HTH
HTH
Wrong clutch switch? There are two. You need to reach the top switch.
Wire colors are black and blue/black
the top one is missing the lower one i replaced i will replace the upper one in the morning after i go to the dealership the upper one is the one i was referring to in my earlier post the one that is pushed in when the clutch is depressed
But if you press the plunger on that switch, that should let the starter run IF that was the problem.
You said it still didn't crank?
Time for a wiring diagram and a test light....
Is the ignition switch any good?
Starter relay?
Dash still lights up when you turn the key on?
Got power to the starter on the small wire when someone tries to start it?
There are a lot of possibilities.
Testing is the key to correct diagnosis.
Starter relay?
yes everything lights up as normal & fuel pump hums as it should i am not sure if the ign switch is ok just happened this afternoon did not get to test it yet will check in the morning i really appreciate your assistance w/ this issue
Relay Looks like above and left of the dash fuse box.
2 black/white wires
1 blue/black
1 black/red
This link has a wire diagram for that cars starter system
http://www.2carpros.com/questions/19...vic-wont-start
2 black/white wires
1 blue/black
1 black/red
Check out the entire thread in the link, it covers this pretty well.
after replacing the little rubber from the clutch pedal diagram it still did not start so i then moved on to testing to see if i had 12v from the trigger wire on the starter to which i do then i checked to see if i was getting 12v at the batt connection on the starter which i am turns out the problem was corrosion on the trigger wire connection on the starter cleaned it up & BAMM the civic came back to life once again a BIG thanks to ezone for all your help
SSMatey
Apr 13, 2015 06:09 PM
