93 civic with issues with fuel pump
Old Nov 20, 2013
ottsixx's Avatar
ottsixx is an unknown quantity at this point
I have a 93 civic DX 4 door that always started about as fast as you would engage the starter it was running and all of a sudden it wont start and there was nothing it would just crank and crank like there was no spark at all so I pulled the fuel line to the filter and not a drop of fuel I even energized the ignition and heard the little hum the fuel pump makes when energized for a fuel seconds so I put a new pump in it and it still wont start and very little fuel to the filter with the key and yet I heard the pump buzz for a few seconds so the next thing I noticed is that I don't have any voltage to the fuel pump or fuel gauge and when I check the fuses inside and out they all BEEP! with continuity as it appears according to my test meter anyone got any clues to make this Honda run again.
Old Nov 20, 2013
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: 93 civic with issues with fuel pump
Check the main relay under the driver dash/kick panel. They are know to have bad solders so you may need to resolder the board.
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
McD
Apr 29, 2015 03:50 PM
McD
Apr 22, 2015 05:28 PM
