valve cover issues
Old Oct 16, 2013
Gooses's Avatar
Gooses is an unknown quantity at this point
Question valve cover issues
hey everyone, just needed some insight and advice on an issue im having, motor is a D16Z6and I was putting my valve cover back on today after replacing the gaskets and the front three bolts wont tighten, they screw down right to the point of where they should grab and tighten but they just spin. the bolts themselves arnt stripped so im not sure whats going on there, and then one of the two longer bolts in the back snapped off, i wasnt even wrentching on it hard or anything either, it got to the point where it started to grip and i gave it a slight turn and it just broke off. at this point im not really sure what my options are for this kind of situation so im open to helpful advice on it. thank you in advance to anyone that can help!
Old Oct 17, 2013
Re: valve cover issues
Stripped holes, Heli-coil.
Broken bolts, replace.
Put both together, and I say you gotta stop being a gorilla on those little bolts.
Use a torque wrench and proper specs if you don't have a "feel" for tightening.
Old Oct 17, 2013
BlueEM2's Avatar
Whachya lookin at?
Hmm... I have the "feel". It's usually 1/4 of how tight I think it should be!!! Hasn't failed me yet.
Old Oct 17, 2013
There's a scary number of people in this profession that have no sense of, never got, and will never ever have the "feel" for tightening anything by hand.
Sad part is most don't know it, don't realize it, can't admit it, and refuse to use torque wrenches when needed.
They keep on breaking and stripping stuff. Guess what happens next.
Old Oct 17, 2013
BlueEM2's Avatar
Whachya lookin at?
I've seen a guy install a ball joint nut by using a pneumatic impact on it Now that's accurate.
Old Oct 17, 2013
I do it all the time......But that's a bit different from a 6mm valve cover bolt going into aluminum.
Old Oct 17, 2013
BlueEM2's Avatar
Whachya lookin at?
Do it all the time until the holes line up or until it stops spinning?
Old Oct 17, 2013
That's what she said....
Wait, whut?
Old Oct 17, 2013
BlueEM2's Avatar
Whachya lookin at?
Now I'm confused. I know that's pretty normal nowadays but I mean I'm more confused than normal.
Old Oct 17, 2013
I use air tools every chance I can.
Speed is time, time is money.
But if I do it wrong, I get to do it over again for free.
(This is a test, this is only a test) I will use an impact gun to "install" spark plugs and make sure the new guy in the shop sees me do it. Most freak out if they know anything at all. The ones that don't see a problem with it are the ones I worry about.
Old Oct 17, 2013
BlueEM2's Avatar
Whachya lookin at?
Hmm... I'd be running at you with crescent wrench
Old Oct 17, 2013
Here's something most people don't get: The triggers of my impact guns are more than just ON-OFF switches.
Me feathering the trigger of an impact gun as it were a throttle CAN net more accurate results than the next guy with a ratchet. Or a crescent wrench.
Gotta know your tools.
I am perfectly willing to use my 3/8 gun on those small valve cover bolts, but I use my 1/4 air ratchet on them more often. Either one will strip or break them if I let it.
Supramk3
May 11, 2015 07:55 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
bambuski
Dec 16, 2001 05:57 PM
