Idle RPM Bouncing?
Idle RPM Bouncing?
When the car is on drive the rpm is normal at about 1000 with my foot off the pedal, but as soon as it is on park the rpm starts to go up to about 2000 to 2200 after i leave it running it starts to lower and come back up. Can anybody explain this? maybe vacuum leak is what i'm told. and should i be worried? also while i'm driving the gas pedal seems to loose throttle, is this problem connected with changing rpm ... Please help.
Re: Idle RPM Bouncing?
Y/M/M?
This is posted in 8th-9th gen, and you don't appear to have one of those cars.
Coolant level
Coolant flow
Coolant temperature
CTS reading skewed
Vacuum leaks
Sticking IAC
Sticking FICV
Misadjusted and/or hacked throttle and/or TPS
Coolant level
Coolant flow
Coolant temperature
CTS reading skewed
Vacuum leaks
Sticking IAC
Sticking FICV
15EXCoupe
Jul 30, 2015 12:59 PM
cizsak
Jul 21, 2015 03:39 PM
brennov8
Jul 13, 2015 12:57 PM
cgavin1
Jul 7, 2015 07:10 AM
