'89 Civic 1.5L shakes on idle with lights on
Old Sep 7, 2013
Hunk of Cheese's Avatar
Hunk of Cheese is an unknown quantity at this point
I have an '89 Civic hatchback 4-speed, bare-bones base model.
At idle, it's smooth and steady. Couldn't ask for better.
If I put the lights on or turn on the cabin fan, the engine RPM drops a bit, but the idle stays steady and solid at the lower RPM.
BUT, now the whole car is vibrating, the door panels rattle, coins in the glove box rattle, tools in the way back rattle, it's a mess.
The car doesn't have a tachometer, so I can't say exactly what RPM it's idling at. It sounds ok to me though, not crazy low or anything. I think the idle speed is computer-controlled here with no manual adjustment anyhow.
So far my only guess is maybe the engine mounts are bad. Any other hints what might cause this level of vibration in the cabin when the engine is idling steady?
Old Sep 9, 2013
Poopies's Avatar
Super Moderator
Re: '89 Civic 1.5L shakes on idle with lights on
Sounds like a pretty reasonable guess. Have you tried looking under the hood or lifting the car to take a look under it yet? How old is your timing belt?
Old Sep 14, 2013
No idea how old the timing belt is. Replacing the clutch this week so I'll inspect the mounts while I'm doing that.
Can a worn timing belt cause vibration like this without rough running??
Old Sep 15, 2013
Poopies's Avatar
Super Moderator
Well there could be a lot of causes but an old, worn timing belt with missing teeth and such could potentially be the most problematic!
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
