1991 DX Sedan-weird hesitation-sputtering-stalling
Started to experience hesitation, stalling, and sputtering when accelerating from standstill. Need to put in N when sitting at a red light, gets really bad when I turn on the A/C. Trying to troubleshoot by process of elimination. So far I have changed spark plugs, spark plug wires, distributor cap, air filter, and fuel filter. The next thing on my list is the O2 sensor which is fairly easy to reach on this model, but not sure if there is anything else I should check/replace first. Any input or suggestions would be greatly appreciated!
Re: 1991 DX Sedan-weird hesitation-sputtering-stalling
Tried cleaning your Idle Air Control Valve (IACV)? http://honda-tech.com/showthread.php?t=1575913
How are the fuel injectors? Do you use top-tier gas only? Do you ever use any additives to clean the system?
Zygrene
Mar 22, 2016 12:36 PM
Islesfan
Sep 29, 2015 03:42 AM
Monty022581
Aug 31, 2015 08:32 AM
beeemerdude
Jul 23, 2015 03:53 PM
