Turn signal flash rate. One side is DIM
Old Jun 15, 2013
trainingwheels's Avatar
trainingwheels is an unknown quantity at this point
I am asking your help in tracking down a problem with my turn signals.
I have a 95 Civic 4 door.
The turn signals operate as normal on the passenger side.
On the drivers side the turn signal flashed at a rate double the one the passenger side, while the drivers side front turn signal is very dim compared to the flasher on the passenger side.
I have checked the fuses and find nothing wrong.
Can you please tell me what to check and/or replace?
Thank you.
Robert
Old Jun 16, 2013
GolNat's Avatar
Prelude Owner
Re: Turn signal flash rate. One side is DIM
I believe the side that is flashing twice as fast means that you have a bulb out. Check the blinker on the driver side rear.
Old Jun 16, 2013
Or the dim one on drivers front, it may not be drawing enough current.
Old Jul 21, 2013
TheRepairMan's Avatar
TheRepairMan is an unknown quantity at this point
... the drivers side front turn signal is very dim ...
Thank you.
Robert
There's your clue.
It sounds like corrosion has taken over, unless some other event took place. I'd take that bulb out and clean the contacts on it, and the socket, or clean the socket and replace with a known good bulb.
-R
Old Jul 21, 2013
CraigW's Avatar
Yes, start at the dim bulbs socket and work back. Poor connection at some point.
Old Nov 14, 2019
Carlost.'s Avatar
Carlost. is an unknown quantity at this point
Thank you.
Robert
I have an 07 with the same issue ....did u ever figure out what caused it? Would like to know please and thank you in advance
Old Nov 15, 2019
Colin42's Avatar
Thread is 6 years old........
Bulb may just be old or there's a bad/loose connection, or a half broken wire
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
GhettoCivic
Nov 12, 2001 03:15 PM
