93 Civic Hatch, B18B1 swap idle/jerking problems
Old Oct 2, 2012
x scriizz's Avatar
Ride with Pride
x scriizz is an unknown quantity at this point
Question 93 Civic Hatch, B18B1 swap idle/jerking problems
Hey i have a 93 civic hatch with a B18B1 swap, It also has Brian Crower cams so i am aware the revs will fluctuate at idle because of the cams.
At cold start up it will idle at 2000rpm, after it warms up it will drop down to about 800 at idle, but it will also drop up and down from 100-1000rpm and very rarely it will just stall out, i cleaned out the IACV with some break cleaner already and it seemed to keep the idle at 800rpm for about an hour but then the problem reoccurred.
Second Problem:
When driving at a constant rpm 2000-3000 usually in 4th or 5th gear, the car will jerk/hesitate, but as soon as i step on the gas a little it will power through the jerk or hesitation.
Im still learning a lot about my car and how to find and fix the problems, Help on these would be much appreciated.
I always put 91 or 94 octane in the tank
Thanks
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
May 10, 2015 08:11 AM
Rinzlor
Apr 24, 2015 10:33 AM
chirp the 1-2
Apr 19, 2015 02:19 PM
NROD315
Apr 16, 2015 08:40 AM
