95 Coupe Idle Issue
Old Aug 27, 2012
Lunchbox_Munchy's Avatar
Lunchbox_Munchy is an unknown quantity at this point
95 Coupe Idle Issue
How's it. I have a 95 Coupe and it's idling crazy. Occasionally, it'll start to fluctuate. It'll go up to around 1500-2000 and then back down to 500-1000. It doesn't always happen. It normally starts after a few minutes of driving. I don't drive hard or anything. Just trying to keep this running until I can swap it out. Thanks.
Old Aug 31, 2012
Fragmare's Avatar
Fragmare is an unknown quantity at this point
Re: 95 Coupe Idle Issue
Try removing, disassembling and cleaning the IACV with brake cleaner.
If that doesn't do the trick, remove the throttle body, take off the Fast Idle Valve, disassemble it and clean it thoroughly with brake cleaner (be careful with the rubber o-rings, a couple of them are odd shaped and probably brittle from age, so if you tear them you're off to find a new FIV most likely). Then thoroughly clean the throttle body itself with some carb cleaner, a shop towel, an old toothbrush and some pipe cleaners. Put it all back together and use a new throttle body gasket (duh).
If it's still acting up, double check your mechanical timing and ignition timing.
If those are fine, run the idle adjustment procedure. When you do the idle adjustment, while the engine is still cold and you've got it warming up to operating temperature (but NOT when the engine is hot) that would be a good time to also poke around the hoses with some propane, carb cleaner or starting fluid and see if there are vacuum leaks. If there are, repair the vacuum leak, obviously.
If none of those things do the trick, you might need to start looking for a new IACV and/or FIV.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
crowtoo
May 11, 2015 06:50 PM
Pr0n1s
Apr 30, 2015 03:08 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
