New TPS, Still throwing CEL codes 3/7!?? HELP!!
Old Aug 7, 2012
92EGSIRII's Avatar
92EGSIRII is an unknown quantity at this point
Exclamation New TPS, Still throwing CEL codes 3/7!?? HELP!!
NEED HELP!!!
So i have a 99 SIRII B16A2 engine in my 92 EG hatch. Just recently i had issues with idle, richness etc. i had a CEL - TPS sensor throwing and so i went out and just purchased a new OEM replacement. I put it ont my TB and plugged it in, and still popping the CEL light not only with the #7 TPS code but now the #3 Code for my Map sensor as well. i have checked everything i could and still no success. when i try to drive its suuuper rich i get maybe 200km to a full tank, and when i rev hard it boggs out and will backfire like a bitch!!!! i cannot figure this out at all i will post a vid later for you all to see whats goin on. i idle at about 1200rpm when warm. So since i bought a new TPS and my old MAP sensor was okay before this issue, what possibly could be the issue. Its running OBD1 with a P28 ECU... she worked fine till i went to replace my TPS and now im throwing these 2 codes and no leway in figuring out the source of the issue... any help would be great guys!!!!!
SHe is running like crap and i just want her back to normal :P
Old Aug 7, 2012
92EGSIRII's Avatar
Re: New TPS, Still throwing CEL codes 3/7!?? HELP!!
bump for help guys!!
Old Aug 8, 2012
92EGSIRII's Avatar
Well still waiting on some help guys!!! She now backfires like mad when I try to pull away and is starting to slowly just overheat from this issue plus I get like noooo gas I'm just pretty much waisting gas, I cannot figure this out!
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
magog45
Jul 9, 2015 06:23 PM
