In desperate need of some help!
Old Aug 5, 2012
DIYmechanik's Avatar
DIYmechanik is an unknown quantity at this point
I have a 1991 Honda Civic Lx 1.5 sohc. i recently put in a new battery, new starter, new plugs, new wires, new cap and rotar. it was running just fine until i filled it with gas. now it doesn't start. It will crank but just wont fire up. It sounds like its choking every time i try. and puffs out a little bit of smoke when i stop trying to start it from the air filter. its getting fuel but no spark. Could it be bad timing or just bad wires? Please i really need some help with this, thank you!!!
Old Aug 13, 2012
angelmar06's Avatar
angelmar06 is an unknown quantity at this point
Re: In desperate need of some help!
Yeah it's bad timing your blowing out smoke thru you'r intake get it checked out
Old Oct 13, 2012
zoomersgarage's Avatar
zoomersgarage is an unknown quantity at this point
check the firing order and make sure the wires are places in the right cylinders. If there is no spart from any of the wires; most likely it is a bad ignition coil.
Dan Head
Jun 10, 2015 01:31 PM
civic1316
May 29, 2015 05:13 PM
Nodnero
South Cali
Jul 19, 2003 06:45 PM
FlippedOut
Oct 15, 2002 09:27 PM
