help required (amp)
Old Oct 12, 2002
FlippedOut's Avatar
FlippedOut is an unknown quantity at this point
help required (amp)
desperate help required
my subs are not pounding at all.
i checked the fuse up at the front from the battery. that fuse is fine.
checked and double checked all the wirings, and they are where they are suppose to be
does that mean that the fuse in the amp is blown?
how can i be absolutly sure?
Old Oct 12, 2002
WhiteRabbit's Avatar
not pounding, or not even playing?
Old Oct 12, 2002
FlippedOut's Avatar
good point whiterabbit.. thanks...
the subs aren't playing at all [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Oct 12, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
the fuse in the amp is pretty easy to access. just take a look and see if it's still good. if it is then maybe you connected the speaker wires too far in and all the connections aren't made because the insulation on the speaker wires prevents it. I've seen it more than once so check it out.
Old Oct 13, 2002
FlippedOut's Avatar
i've already checked to make sure it's not the insulation...
Old Oct 13, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
have you checked the subwoofers themselves? maybe the voice coils fried? disconnected speaker wires inside the sub box?
Old Oct 13, 2002
Ed's Avatar
Ed
Is the amp's led light on?
Maybe your HU's sub output got turned off somehow, if you have an aftermarket?
This happened to me once, I popped the tube fuse on teh wiring kit and the fuse i replaced it with was jsut barely too short, so sometimes the fuse would tough both ends, sometimes not. It's a long shot [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Oct 13, 2002
FlippedOut's Avatar
Quote
[hr]Originally posted by: Ed
This happened to me once, I popped the tube fuse on teh wiring kit and the fuse i replaced it with was jsut barely too short, so sometimes the fuse would tough both ends, sometimes not. It's a long shot [IMG]i/expressions/face-icon-small-tongue.gif[/IMG][hr]
yeah the led goes on...i know it's receiving power...
i have a dvd system.. and the output from the receiver, i wouldn't know if it's turned off... i wouldn't think so...
i'll be checking if it's the subs today... i hope it's not the subs...
Old Oct 15, 2002
FlippedOut's Avatar
i tried an alternative set of subs from a friends car...
so im thinking that it's the amp b/c the subs are not gettin any kind of power at all...
Old Oct 15, 2002
mohawkboom's Avatar
Hi Flipped,
Have you checked the fuses on the amp?? It has a pair of 25 or 30 amp fuses.. Also the amp has a strict protection cicuit..if your voltage ever dropped below 10 volts you have to disconnect the power and ground wires from the amp for about 30 minutes. This will reset it.. Where did you ground the amp??..if it doesn't have a good ground the voltage drops..
Cheers
Mohawk
Old Oct 15, 2002
FlippedOut's Avatar
the 30 fuses are fine...
the ground was placed underneath the backseats and is secure.
thanks for the info...
i think your right about the 10 volts // because i found the power line not attached very strongly and coming lose //
i'll reset them tonight...
Old Oct 15, 2002
mohawkboom's Avatar
Email me any updates Warranty is up on November 5th...
Old Oct 15, 2002
FlippedOut's Avatar
emailed you
Old Oct 15, 2002
mohawkboom's Avatar
No you didn't [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. got the email about you posting..but not te email from you..
it's dmtp@lycos.com
Old Oct 15, 2002
FlippedOut's Avatar
i emailed your msn one.. hehe.. rugby......
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
