CEL on, won't rev past 4k, P2647 code
Old Jul 25, 2012
hoppy's Avatar
hoppy is an unknown quantity at this point
First off, new to this forum, and I am on several other forums for various things.
This is in an '05 honda civic Si 2.0, completely stock, my wife's car.
The symptoms are:
1) The CEL is on and the code is P2647 which has to do with the vtec oil pressure solenoid.
2) Engine won't rev past 4k, acts like there's a limiter at 4k.
3) very poor gas mileage
4) A hose was disconnected from what looks like the vtec pressure solenoid and the tube for the air intake that goes between the filter and the intake manifold.
-I reconnected the hose and it revved past 4k a couple times, but when I cut off the engine and restarted, it was back to not revving past 4k.
The story is that I was replacing the upstream o2 sensor, and to see if the maintenance req'd light would go off, I drove it fast & hot to getthe operating temp up quicker, that's when the CEL came on and the dtc was 2647. This all happened on this past sunday.
I searched through these forums prior to this post and the most helpful thread i found was this one https://www.civicforums.com/forums/3...re-switch.html
which wasn't any help at all.
This car is a daily driver, and I need it to be fixed asap.
What does this code mean? for the filter screens to be cleaned in the solenoid, or for the whole thing to be replaced, or for the code to be cleared after reconnecting that hose, or...???
My goal is to NOT throw parts and $$$ at it till it's fixed, and to figure out exactly what the issue is and fix it without trying a few things first.
Thanks in advance!
Old Jul 26, 2012
hoppy's Avatar
Re: CEL on, won't rev past 4k, P2647 code
someone has to have had experience with this
any ideas? I'd like some insight before I dig into this problem, and I know there's a lot out there.
First I'm going to check the solenoid, if the filter is dirty then I'll clean it, and see if that fixes anything. If not then I'll probably just replace the solenoid.
Old Jul 26, 2012
GolNat's Avatar
Prelude Owner
This looks like one for ezone.
Old Jul 27, 2012
hoppy's Avatar
the hose that was disconnected from the tube between the intake manifold and the airbox seems to go to some type of vacuum switch dealing with the coolant. It had a temp sensor on it, and I assume that's not part of the vtec solenoid.
Old Jul 31, 2012
hoppy's Avatar
well, no help from anybody on here, but I figured it out. On my civic, the engine is positioned where the intake manifold is up front neat the rad, and the exh manifold is going straight out the back, the vtec spool is in the back left of the engine bay, obviously right on the side of the cyl head.
Also, my cel went off this morning and it drives like normal. I'm going to buy the oil pressure switch anyways, because it's bound to happen again.
Hope this thread is a help to anyone else who might have this problem in the future!
Old Aug 31, 2012
dloc82295's Avatar
dloc82295 is an unknown quantity at this point
So I am having a very similar problem with my 93 civic dx, what was the problem in the end? I have replaced the plugs wires ignition coil an the icm, but it won't accelerate past 3500rpms
Luluharp
Sep 27, 2015 11:56 AM
pilebuck13
Sep 21, 2015 10:45 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
Bricoleur
Sep 9, 2015 06:48 PM
jpat21
Sep 3, 2015 11:32 PM
