1994 Honda Civic Wont Start
Old May 8, 2012
AndrewB814's Avatar
AndrewB814 is an unknown quantity at this point
My 1994 honda civic wont start. I have replaced the distributor the plugs and wires, map sensor, throttle position sensor, ignition switch and every once in a while it will start for maybe a minute then shut off all the other times it doesnt start. It has code 15 coming up which is ignition output signal. Does anyone know what it could be???
Old May 9, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Re: 1994 Honda Civic Wont Start
It has got to be the ECU , you have replaced everything else. You should be able to find one on ebay for 30 or 40 bucks. Or if you have any friends with the same car, swap one in to test it.
Old May 9, 2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Check your fuel relay under the drivers dash. They are known to have cracks in the solder.
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
twtron
Apr 17, 2015 12:09 AM
gabrown2
Apr 11, 2015 08:22 PM
