Air escaping noise while accelerating/loss of power
Old Jan 20, 2012
julius6000's Avatar
julius6000 is an unknown quantity at this point
Bear with me here, I don't know much about cars. I have a 92 bubble with a d15b. While accelerating from a stop this morning, I heard a whooshing noise coming from (i think) under tge car and had barely any power. It sounded like air escaping that got louder the more I hit the gas. I pulled over to see where it was coming from but it wouldn't do it in park. Only drive and reverse. Turned the car off and back on and it was fine. This is the 2nd time it happened. The first time resulted in a hunting idle that was remedied with a new iacv and a fitv block-off plate.
Any ideas what this is? My guess was vacuum leak, but it idled fine this time, just the noise and loss of power. Any help would be appreciated more than you know.
Old Jan 20, 2012
julius6000's Avatar
Re: Air escaping noise while accelerating/loss of power
. Also since the first time it happened, exhaust is louder and car shakes at idle and certain RPM's
Old Jan 21, 2012
lazlong's Avatar
Loud wooshing, loss of power- sounds like a clogged exhaust. Look for exhaust leaks but, I bet it's clogged. LIGHTLY tap the catalytic converter and listen for rattles. If you hear stuff rattling around in the cat then you need a new cat.
Also, check for codes: http://check-engine-light-codes.blog...retrieval.html
Old Jan 24, 2012
julius6000's Avatar
Thanks. it does rattle. Ill have my guy replace it.
anddrrey
May 11, 2015 02:30 PM
cloudguy
Apr 28, 2015 05:02 AM
SSMatey
Apr 13, 2015 06:09 PM
plastikman
Bolt-on Engine Performance
Dec 13, 2001 03:18 PM
silvervtec01
Dec 9, 2001 08:50 PM
