Catalytic Converter or Fuel Leak?
Old Jan 27, 2012
sellis1552's Avatar
sellis1552 is an unknown quantity at this point
Lately I have lost power in my 94 Civic EX Coupe VTEC. When I punch it, it doesn't have the same acceleration anymore. I have also been getting worse fuel economy. Occasionally when I start it, it doesn't seem to get enough gas and wants to stall. I do smell gas occasionally when it's running, at a red light, or parked, but i'm not sure if that's because I have an aftermarket exhaust. I do hear air when I step on it though, which makes me lean more towards the catalytic converter. Maybe it's both? Thanks for the help.
Old Jan 27, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Re: Catalytic Converter or Fuel Leak?
after you have driven it , jack it up and check the gas tank and undercarriage for wet spots, then check around the fuel filter and fuel injectors. they leak a lot around the seals. anytime you smell gas you should isolate the problem immediately
vtecbrah
19
Jun 5, 2015 09:38 PM
Shakzhussain
May 17, 2015 12:03 PM
BootyDo
May 8, 2015 05:36 PM
ayzan
24
Apr 17, 2002 06:55 PM
Lightman
Nov 10, 2001 06:44 PM
