Bad brake light switch and sticky throttle
Old Nov 30, 2011
Ef_Grocry_Getr's Avatar
Ef_Grocry_Getr is an unknown quantity at this point
Ok heres the thing as i idel when i start the car the idel stays around 800 where its supposed to be and as i begin to drive its fine except for when i come to a stop and the ideal stays up and in order for it to come down i have to stick my foot underneath the gas pedal and pull up after i do tht the idel goes back to 800 I cant figure out why the idel stays high. Ive adjusted the throttle cable but it didnt work also rear brake lights dont work but everyother light works turning signals running lights etc. replaced the bulbs already and checked the brake light switch it doesnt seem bad but then again i never had one go out could it just be a bad switch Got any advice ?
Ef_Grocery_Getter
Old Dec 1, 2011
CraigW's Avatar
Re: Bad brake light switch and sticky throttle
Horn working ? (share a fuse)
Next step would be to measure voltage. 1 side should have constant 12 volts, and other side should have 12 volts when pedal pressed.
Poopies
Apr 20, 2017 11:36 PM
Flipg123
May 8, 2015 01:15 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
klam
Nov 16, 2001 03:36 PM
