setting timing on 1.5l
Old Jul 13, 2011
B18_civic's Avatar
B18_civic is an unknown quantity at this point
I have a 95 civic with a 1.5 liter engine and upon purchasing it I notice that the distributor is jimmy-rigged. The timing wasn't set right and they had to retard/advance the distributor past the slots for the bolts to hold the distributor in the head. Using the cup off a rear wheel drive shaft U-Joint and the bolt is how the distributor is held in place. On the crank there are four marks. I I I I something like that. what mark do I go by there and what do I use on the cam. please help.
Old Jul 16, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: setting timing on 1.5l
go and spend 30 dollars on a book from autozone or advanced which ever you prefer and it will solve your problem and well worth your money
jbradley4809
Apr 7, 2017 04:23 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bsmiley
Apr 27, 2015 01:27 PM
SpoonSportsd17a
Nov 19, 2001 09:26 AM
silvercallx
Aug 19, 2001 12:36 AM
