'95 _ gas smell
Old May 11, 2011
CivicHeadd's Avatar
CivicHeadd is an unknown quantity at this point
'95 _ gas smell
I have this gas smell inside my car, is coming from between my back seat & trunk. Smells stronger when iopen up my trunk. Ichecked the tank under the backseat & everything seems to be in place & decent condition. Is strange but the smell isn't coming from there, is very strong between that location & trunk. Right above of where the spare tire is in the trunk. Also the gas meter acts up a little, not sure if it has to do with the smell but when is parked (example) car has half tank full, when I'm driving the meter would say I'm a little over a quater tank of gas. Helpppp
Old May 11, 2011
MelJ's Avatar
Trance Addict
Re: '95 _ gas smell
The filler neck might be rusting out or a leak somewhere. Where do you live at? I've heard that older cars seemed to have this issue(filler neck). The meter may change depending on ground level. If you go up a hill, it'll usually dip lower because the gas is all going to one side of the tank. It has to do with what monitors the gas level. Usually a float is what monitors it in out Civics. Some cars don't use that type of level sensor.
Old May 11, 2011
CivicHeadd's Avatar
Re: '95 _ gas smell
Live in garfield. Couple hills here & there. But where would the filler neck be located ?
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
WaryDriver
Aug 22, 2015 06:50 PM
GritzNGravy
Aug 19, 2015 03:03 AM
