first honda and need help
Old Apr 21, 2011
skeez94civic's Avatar
skeez94civic is an unknown quantity at this point
Need to kno what kind of options i have with a stock 1.6L SOHC V Tech. Is the engine worth putting money into it or should i just invest in another motor. Whats the best route. Any suggestions will b looked into and considered. Thanks.
Old Apr 21, 2011
secondcivic's Avatar
secondcivic is an unknown quantity at this point
Re: first honda and need help
Hi, let me be the first to welcome you to the honda community!! First i'll give you a heads up its VTEC not V tech, its not a phone manufacturer its a Honda. Second a little more information on which specific D-series sohc would be helpful in determing whats best, but ultimately its up to you. listed below are the sohc VTEC engines that come with you model year.
D15Z1-1.5L 16V SOHC VTEC-E, 92hp @ 5500 RPM
D16Z6-1.6L 16V SOHC VTEC, 125hp @ 6600 RPM
There are more non VTEC engines that come with you model year as well but If it is VTEC I see no reason to list them.
Lastly since your civic is in OBD1 it has the best platform for modication since there is less O2 senors to trip. Also the best part, is that your car engine bay chassis is identical to the Integra 94-01 model so it is a simple bolt on procedure to get a B-series powerplant in there without needing to find a compatable A/C or powersteering brackets and since your car is already VTEC you do not have to solder in a VTEC solenoid or knock sense to the engine harness.
I hope this helps you with determing in what you want to do, and best of luck.
Old Jun 27, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
dont mess with the sohc start lookin for a b18c1 which is also known as b18 gsr which is vtec or a b16 sir2 which is also vtec but either way you go u will have to get motor mounts computer wiring harness tranny and and cv axles but i believe that will be the best way to go
Jessica Leung
May 5, 2015 05:12 PM
carid
Apr 30, 2015 07:00 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
