Rust in Cylinder Walls???
Old Mar 2, 2011
koolcivi's Avatar
koolcivi is an unknown quantity at this point
Hi ,I just got a civic motor from my friend it came out of a 1990 Honda .It has about 55,000 miles on it.My question is that the motor was stored outside for many years it was covered and the cylinder wall were oiled up and greased but there is still some surface rust on some of the walls .What is the best way to remove it .I want to use the motor the way it is with out doing a complete rebuild just clean up and regasket it.Should i use sandpaper or ???? Please give me your feedback thanks
Old Mar 2, 2011
MindBomber's Avatar
Live for the Twisties
Re: Rust in Cylinder Walls???
The proper way to fix that would be to take the block to a machine shop, if you want to DIY it the only thing I could suggest is an extremely fine grit sand paper or a chemical rust remover. If you make a mistake then you might scratch the cylinder walls and lose compression.
Old Mar 2, 2011
BlueEM2's Avatar
Whachya lookin at?
Take it to a shop it get it properly resufraced or you risk destroying the engine...
Old Mar 2, 2011
lazlong's Avatar
^^ What he said times infinity.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
Bikergofast
Sep 12, 2015 01:36 PM
